Use the following procedure to display the SPB-PIM Gateway neighbor information
- Select SPB-PIM-GW.
- Select the Neighbors tab.
Neighbors Field Descriptions
Use the data in the following table to use the Neighbors tab.
Name |
Description |
IfIndex |
Specifies the IfIndex for the interface which is used to reach this SPB-PIM Gateway neighbor. |
AddressType |
Specifies the address type of this SPB-PIM Gateway neighbor. |
Address |
Specifies the primary IP address of this router on this SPB-PIM Gateway neighbor. |
UpTime |
Specifies the time since this SPB-PIM Gateway neighbor last became a neighbor of the local router. |
ExpiryTime |
Specifies the minimum time remaining before this SPB-PIM Gateway neighbor times out. |
