Configure explicit host tracking to track all the source and group members.
  1. Enter Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} or interface vlan <1–4059>
  2. Configure explicit host tracking:
    ip igmp igmpv3–explicit-host-tracking
  3. Display all the tracked members for a specific group:
    show ip igmp group group <A.B.C.D> tracked-members [member-subnet <A.B.C.D/X>] [source-subnet <A.B.C.D/X>] [port {{sub-port]][,...][slot/all][all]}] [vlan <1-4059>]
  4. Display the IGMPv3 specific data:
    show ip igmp group group <A.B.C.D> detail port {{sub-port]][,...][slot/all][all]}} vlan <1-4059>
Switch:1(config-if)#ip igmp igmpv3–explicit-host-tracking
Display all the tracked members:
Switch:1#show ip igmp group
                           Igmp Group - GlobalRouter
GRPADDR         INPORT          MEMBER          EXPIRATION TYPE       L2ISID
224.5.2.1       V701-1/4        62.0.1.1        214        Dynamic    40400
224.5.2.2       V702-1/4        62.0.2.1        221        Dynamic    40400
224.5.2.3       V703-1/4        62.0.3.1        217        Dynamic    40400
224.5.2.4       V704-1/4        62.0.4.1        223        Dynamic    40400
4 out of 4 group Receivers displayed
Total number of unique groups 2
Switch:1(config-if)#show ip igmp group group 232.1.1.1 tracked-members
                          Members of Channels/Groups - GlobalRouter
INTERFACE       CHANNEL/GROUP         MEMBER           MEMBER_MODE EXP
Vlan333-1/30    */232.1.1.1          133.133.133.200   IS_EXCLUDE  205
Note:
The "*" attached to the interface (if any) indicates that the interface has explicit host tracking disabled.
Display IGMPv3 specific data:
Switch:1(config-if)#show ip igmp group group 232.32.32.10 detail
                        Igmp Group Detail - GlobalRouter
Interface:                     Vlan222-1/10
IGMPv3 Group:                  232.32.32.10
Interface Group Mode:          INCLUDE
Interface Compatibility Mode:  IGMP_V3
V2 Host Timer:                 Not Running
V1 Host Timer:                 Not Running
Interface Group Include Source List:
        Source Address  Expires
        133.133.133.200 114
Variable definitions
Use the data in the following table to use the ip igmp igmpv3–explicit-host-tracking command.
Variable
Value
Enables explicit host tracking on IGMPv3. The default state is disable.
<A.B.C.D>
Specifies the IP address of the group of the tracked member.
