Configure the multicast router discovery options to enable the automatic discovery of multicast-capable routers.
Important
Important
The switch does not support the Multicast Router Discovery (MRDISC) protocol on brouter ports.
  1. Enter VLAN Interface Configuration mode:
    enable
    configure terminal
    interface vlan <1–4059>
  2. Enable multicast router discovery:
    ip igmp mrdisc
  3. Configure the maximum advertisement intervals between successive advertisements:
    ip igmp mrdisc maxadvertinterval <2–180> maxinitadvertinterval <2–180>
  4. Configure the maximum advertisements after initialization:
    ip igmp mrdisc maxinitadvertisements <2–15>
  5. Configure the minimum advertisement interval between successive advertisements:
    ip igmp mrdisc minadvertinterval <3–180>
  6. Configure the time allowed before a neighbor is declared dead:
    ip igmp mrdisc neighdeadinterval <2–180>
Switch:1(config-if)#ip igmp mrdisc maxadvertinterval 30 maxinitadvertinterval 5
Switch:1(config-if)#ip igmp mrdisc maxinitadvertisements 8
Switch:1(config-if)#ip igmp mrdisc minadvertinterval 30
Switch:1(config-if)#ip igmp mrdisc neighdeadinterval 60
Variable definitions
Use the data in the following table to use the ip igmp mrdisc command.
Variable
Value
Configures the maximum number (in seconds) between successive advertisements.
For this change to take effect, you must save the configuration, and then reset the switch.
To configure this option to the default value, use the default operator with the command. The default is 20.
Configures the maximum number (in seconds) between successive initial advertisements.
To configure this option to the default value, use the default operator with the command. The default is 2.
Configures the maximum number of initial multicast advertisements after initialization.
To configure this option to the default value, use the default operator with the command. The default is 3.
Configures the minimum number (in seconds) between successive advertisements.
To configure this option to the default value, use the default operator with the command. The default is 15.
Configures the multicast router discovery dead interval—the number of seconds the multicast route neighbors for the switch must wait before assuming that the multicast router is down.
To configure this option to the default value, use the default operator with the command. The default is 60.
