Use the following procedure to display the IS-IS interface parameters.
Switch:1>show isis interface
ISIS Interfaces
IFIDX TYPE LEVEL OP-STATE ADM-STATE ADJ UP-ADJ SPBM-L1 OP-SPBM- ORIGIN AREA AREA-NAME
-METRIC L1-METRIC
Mlt2 pt-pt Level 1 UP UP 1 1 10 (A) 10 CONFIG HOME area-9.00.02
Port1/21 pt-pt Level 1 UP UP 1 1 10 (A) 10 CONFIG HOME area-9.00.02
Home: 2 out of 2 Total Num of ISIS Interfaces
Legend:
(A): l1 metric is automatically updated based on detected interface speed.
Switch:1>show isis int-auth home
ISIS Interface Auth
IFIDX AUTH-TYPE AUTH-KEYID AUTH-KEY ORIGIN AREA AREA-NAME
Mlt2 none 0 CONFIG HOME area-9.00.02
Port1/21 none 0 CONFIG HOME area-9.00.02
Switch:1>show isis int-timers home
ISIS Interface Timers
IFIDX LEVEL HELLO HELLO HELLO AREA AREA-NAME
INTERVAL MULTIPLIER DR
Mlt2 Level 1 9 3 3 HOME area-9.00.02
Port1/21 Level 1 9 3 3 HOME area-9.00.02
Switch:1>show isis int-ckt-level home
ISIS Circuit level parameters
IFIDX LEVEL DIS CKTID AREA AREA-NAME
Mlt2 Level 1 1 HOME area-9.00.02
Port1/21 Level 1 2 HOME area-9.00.02
The following table defines parameters for the show isis interface command.
Variable |
Value |
home |
Displays the IS-IS interface information that the system configures in the home area. |
l1 |
Displays the interface information for Level 1. |
l2 |
Displays the interface information for Level 2. |
l12 |
Displays the interface information for Level 1 and Level 2. |
remote |
Displays the IS-IS interface information that the system configures in the remote area. |
The following table defines parameters for the show isis ini-auth command.
Variable |
Value |
home |
Displays the IS-IS interface authentication information that the system configures in the home area. |
remote |
Displays the IS-IS interface authentication information that the system configures in the remote area. |
The following table defines parameters for the show isis ini-timer command.
Variable |
Value |
home |
Displays the IS-IS interface timer information that the system configures in the home area. |
remote |
Displays the IS-IS interface timer information that the system configures in the remote area. |
The following table defines parameters for the show isis ini-ckt-level command.
Variable |
Value |
home |
Displays the IS-IS interface circuit level parameters that the system configures in the home area. |
remote |
Displays the IS-IS interface circuit level parameters that the system configures in the remote area. |
