Switch:1>show isis spbm ip-unicast-fib
SPBM IP-UNICAST FIB ENTRY INFO
VRF DEST OUTGOING SPBM PREFIX PREFIX IP ROUTE
VRF ISID ISID Destination NH BEB VLAN INTERFACE COST COST TYPE PREFERENCE AREA AREA-NAME
GRT - - 10.133.136.0/24 4K3(*) 4058 1/3 10 1 Internal 7 HOME area-9.00.02
GRT - - 10.133.136.0/24 4K3(*) 4059 1/3 10 1 Internal 7 HOME area-9.00.02
GRT - - 10.133.136.0/24 4K4(*) 4058 MLT-1 10000 1 Internal 7 HOME area-9.00.02
GRT - - 10.133.136.0/24 4K4(*) 4059 MLT-1 10000 1 Internal 7 HOME area-9.00.02
Home : Total number of SPBM IP-UNICAST FIB entries 4
Remote: Total number of SPBM IP-UNICAST FIB entries 0
Switch:1>show isis spbm unicast-fib
SPBM UNICAST FIB ENTRY INFO
DESTINATION BVLAN SYSID HOST-NAME OUTGOING COST AREA AREA-NAME
ADDRESS INTERFACE
00:16:ca:23:73:df 1000 0016.ca23.73df SPBM-1 1/21 10 HOME area-9.00.02
00:16:ca:23:73:df 2000 0016.ca23.73df SPBM-1 1/21 10 HOME area-9.00.02
00:18:b0:bb:b3:df 1000 0018.b0bb.b3df SPBM-2 MLT-2 10 HOME area-9.00.02
00:14:c7:e1:33:e0 1000 0018.b0bb.b3df SPBM-2 MLT-2 10 HOME area-9.00.02
00:18:b0:bb:b3:df 2000 0018.b0bb.b3df SPBM-2 MLT-2 10 HOME area-9.00.02
Home: Total number of SPBM UNICAST FIB entries 5
Remote: Total number of SPBM UNICAST FIB entries 0
The following table defines parameters for the show isis spbm ip-unicast-fib command.
Variable |
Value |
all |
Displays entries for the Global Routing Table (GRT) and all Virtual Routing and Forwarding (VRF) instances. Note:
If you use the command show isis spbm ip-unicast-fib the device displays only GRT entries. The command shows IP routes from remote Backbone Edge Bridges (BEBs). |
home |
Displays the IS-IS SPBM IP unicast Forwarding Information Base (FIB) information that the system configures in the home area. |
id <1–16777215> |
Displays IS-IS SPBM IP unicast FIB information by Service Instance Identifier (I-SID) ID. |
remote |
Displays the IS-IS SPBM IP unicast FIB information that the system configures in the remote area. |
spbm-nh-as-mac |
Displays the next hop BMAC of the IP unicast FIB entry. |
The following table defines parameters for the show isis spbm ipv6-unicast-fib command.
Variable |
Value |
all |
If you use the command show isis spbm ipv6-unicast-fib the device displays only GRT entries. The command shows IPv6 routes from remote Backbone Edge Bridges (BEBs). |
home |
Displays the IS-IS SPBM IPv6 unicast Forwarding Information Base (FIB) information that the system configures in the home area. |
id <1–16777215> |
Displays IS-IS SPBM IPv6 unicast FIB information by Service Instance Identifier (I-SID) ID. |
remote |
Displays the IS-IS SPBM IPv6 unicast FIB information that the system configures in the remote area. |
spbm-nh-as-mac |
Displays the next hop as MAC of the IPv6 unicast FIB entry. |
The following table defines parameters for the show isis spbm unicast-fib command.
Variable |
Value |
b-mac <0x00:0x00:0x00:0x00:0x00:0x00> |
Displays the FIB for the specified BMAC. |
home |
Displays the IS-IS SPBM unicast Forwarding Information Base (FIB) information that the system configures in the home area. |
remote |
Displays the IS-IS SPBM unicast FIB information that the system configures in the remote area. |
vlan <1-4059> |
Displays the FIB for the specified SPBM VLAN. |
summary |
Displays a summary of the FIB. |
The following table defines parameters for the show isis spbm unicast-tree command.
Variable |
Value |
<1-4059> |
Specifies the SPBM B-VLAN ID. |
destination <xxxx.xxxx.xxxx> |
Displays the unicast tree for the specified destination. |
