For proper operation, FA must be enabled at both the global level and at the interface level on the FA Server. By default, FA is globally enabled. However, FA is disabled by default at the interface level and must be explicitly enabled on each interface.
Use this procedure to enable Fabric Attach globally on a switch.
    enable
    configure terminal
  2. Enable FA:
    fa enable
  3. Optional: Disable FA:
    no fa enable
    Caution
    Caution
    Disabling FA flushes all FA element discovery and mappings.
  4. View the FA configuration status. Use one of the following commands:
    • show fa
    • show fa agent
Switch:1>en
Switch:1#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Switch:1(config)#fa enable
Switch:1>show fa
                          Fabric Attach Configuration
                            FA Service : enabled
                       FA Element Type : server
                 FA Assignment Timeout : 240
                  FA Discovery Timeout : 240
                     FA Provision Mode : spbm
Switch:1>show fa agent
