View graphs for OSPF on a VLAN. The graph formats available are: line chart, area chart, bar chart, and pie chart.
OSPF must be enabled.
OSPF Field Descriptions
Use the data in the following table to use the OSPF tab.
Name |
Description |
AbsoluteValue |
Displays the counter value. |
Cumulative |
Displays the total value since you opened the OSPF-Graph tab. |
Average/sec |
Displays the average value for each second. |
Minimum/sec |
Displays the minimum value for each second. |
Maximum/sec |
Displays the maximum value for each second. |
LastVal/sec |
Displays the last value for each second. |
VersionMismatches |
Displays the number version mismatches received by this interface. |
AreaMismatches |
Displays the number area mismatches received by this interface. |
AuthTypeMismatches |
Displays the number AuthType mismatches received by this interface. |
AuthFailures |
Displays the number Authentication failures. |
NetMaskMismatches |
Displays the number net mask mismatches received by this interface. |
HelloIntervalMismatches |
Displays the number hello interval mismatches received by this interface. |
DeadIntervalMismatches |
Displays the number dead interval mismatches received by this interface. |
OptionMismatches |
Displays the number options mismatches received by this interface. |
RxHellos |
Displays the number hello packets received by this interface. |
RxDBDescrs |
Displays the number database descriptor packets received by this interface. |
RxLSUpdates |
Displays the number Link state update packets received by this interface. |
RxLSReqs |
Displays the number Link state request packets received by this interface. |
RxLSAcks |
Displays the number Link state acknowledge packets received by this interface. |
TxHellos |
Displays the number hello packets transmitted by this interface. |
TxDBDescrs |
Displays the number database descriptor packets transmitted by this interface. |
TxLSUpdates |
Displays the number Link state update packets transmitted by this interface. |
TxLSReqs |
Displays the number Link state request packets transmitted by this interface. |
TxLSAcks |
Displays the number Link state acknowledge packets transmitted by this interface. |
