Import information from other areas to learn their OSPF relationships. Perform this procedure to create normal, stubby, or not-so-stubby areas (NSSA).
Change the VRF instance as required to configure OSPF on a specific VRF instance. The VRF must have an RP trigger of OSPF. Not all parameters are configurable on non-default VRFs.
Place stubby areas or NSSAs at the edge of an OSPF routing domain. Ensure that you configure all routers in the stubby or NSSA as stubby or NSSA, respectively.
Areas Field Descriptions
Use the data in the following table to use the Areas tab.
Name |
Description |
AreaId |
Specifies a 32-bit integer that uniquely identifies an area. Area ID 0.0.0.0 is the OSPF backbone. For VLANs, using the default area on the interface causes LSDB inconsistencies. |
ImportAsExtern |
Specifies the method to import ASE link-state advertisements. The value can be importExternal (default), importNoExternal, or importNssa. |
SpfRuns |
Specifies the number of SPF calculations performed by OSPF. |
AreaBdrRtrCount |
Specifies the number of area border routers reachable within this area. Each SPF pass calculates this value, initially zero. |
AsBdrRtrCount |
Specifies the number of autonomous system border routers reachable within this area. Each SPF pass calculates this value, initially zero. |
AreaLsaCount |
Specifies the total number of link state advertisements in this area LSDB, excluding AS-external LSAs. |
AreaLsaCksumSum |
Specifies the number of link-state advertisements. This sum excludes external (LS type 5) link-state advertisements. The sum determines if a change occurred in a router LSDB and compares the LSDB of two routers. |
AreaSummary |
Specifies whether to send summary advertisements in a stub area. |
ActiveifCount |
Specifies the number of active interfaces in this area. |
AreaNssaTranslatorRole |
Indicates if the NSSA border router can perform NSSA translation of Type 7 LSAs to Type 5 LSAs. The possible values are always or candidate. The default is candidate. |
AreaNssaTranslatorState |
Indicates if and how an NSSA border router translates Type 7 LSAs to Type 5 LSAs. The possible values are:
AreaNssaTranslatorStablilityInterval |
Specifies number of seconds after an elected translator determines its services are no longer required. |
AreaNssaTranslatorEvents |
Specifies the number of translator state changes that have occurred since the last boot up. |
