Use the data in following table to use the show energy-saver eee statistics command.
Perform this procedure to display information about Energy Efficient Ethernet (EEE) statistics for all ports on a switch, or for a specific port.
  1. To enter User EXEC mode, log on to the switch.
  2. Display information about all ports or specify a particular port:
    show energy-saver eee statistics [{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}]
Switch:1>show energy-saver eee statistics
                                EEE Port Status
         EEE           Tx          Tx              Rx           Rx
PortId   Status        LPI Events  Idle Duration   LPI Events   Idle Duration
                                   (micro seconds)              (micro seconds)
1/1      enabled       847         963657920       115          965100020
Variable
Value
Identifies the slot and port in one of the following formats:
  • a single slot and port (slot/port)
  • a range of slots and ports (slot/port-slot/port)
  • a series of slots and ports (slot/port,slot/port,slot/port)
  • all ports on the same slot (slot/all)
  • all ports on the switch (all)
