BFD for IPv6 interfaces is a demonstration feature on some products. For more information about feature support, see Fabric Engine and VOSS Feature Matrix.
To perform this procedure on a non-default VRF, you must first change the VRF instance. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View. All parameters might not be available in non-default VRFs.
BFD provides a failure-detection mechanism between two systems. Use the following procedure to display information about BFD sessions. You can optionally display BFD session information for IPv4 or IPv6 interfaces.
- Select BFD.
- Select the Sessions tab.
- Optional: Select Filter.
- Optional: Select AddrType.
- Optional: In AddrType, specify a value for address type.
BFD Sessions Field Descriptions
Use the data in the following table to use the Sessions tab.
| Name | Description |
Discriminator |
Specifies the local discriminator that uniquely identifies the BFD session. |
RemoteDiscr |
Specifies the discriminator of the remote system in the BFD session. |
UdpPort |
Specifies the UDP Port for the BFD session. The default value is the well-known value for the port. |
State |
Specifies the state of the BFD session. Possible values are Down, Up, Init, and AdminDown. |
Addr |
Specifies the IP address of the interface associated with the BFD session. A value of unknown (0) indicates the BFD session is not associated with a specific interface. |
DesiredMinTxInterval |
Specifies the preferred minimum interval for transmitting BFD control packets by the local system. |
ReqMinTxInterval |
Specifies the minimum interval for transmitting BFD control packets that the local system can support. |
DestAddr |
Specifies the destination IP address of the interface associated with the BFD session. |
OldState |
Specifies the old state of the BFD session. |
App |
Specifies the applications configured on the BFD session. |
AppRun |
Specifies the applications running on the BFD session. |
AddrType |
Specifies the IP address type of the interface associated with this BFD session. Possible values are ipv4 and ipv6. |
