BFD for IPv6 interfaces is a demonstration feature on some products. For more information about feature support, see Fabric Engine and VOSS Feature Matrix.
To perform this procedure on a non-default VRF, you must first change the VRF instance. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View. All parameters might not be available in non-default VRFs.
BFD provides a failure-detection mechanism between two systems. Use the following procedure to enable BFD globally.
Enabling BFD globally does not establish a BFD session. To establish a BFD session, you must enable BFD at the interface level and at the application level.Procedure
- Select BFD.
- Select the Globals tab.
- In AdminStatus, select enabled.
- Optional: Select TrapEnabled to send BFD traps.
- Select Apply.
BFD Globals Field Descriptions
Use the data in the following table to use the Globals tab.
| Name | Description |
AdminStatus |
Specifies whether BFD is enabled. |
VersionNumber |
Specifies the current version number of the BFD protocol. |
TrapEnabled |
Specifies whether BFD traps are sent. |
