Configure the packet sampling rate at port level to determine how many packets the system counts before it takes a sample. Configuring the sampling rate enables sFlow on the port.
You must globally enable sFlow.
If you configure a conservative sampling rate to prevent overloading the sFlow agent, the result will reflect high values that do not reflect typical traffic levels.
Configure sampling rates for ports 2/1, 2/2, 2/3, and 2/4.
Switch:1(config-if)#interface gigabitethernet 2/1,2/2
Switch:1(config-if)#sflow collector 1
Switch:1(config-if)#sflow sampling-rate 10000
Switch:1(config-if)#interface gigabitethernet 2/3
Switch:1(config-if)#sflow collector 2
Switch:1(config-if)#sflow sampling-rate 8192
Switch:1(config-if)#interface gigabitethernet 2/4
Switch:1(config-if)#sflow sampling-rate 12001
Switch:1(config-if)#show sflow interface enabled
sFlow Port Configuration Info
Port Packet-Sample-Rate Max-Header-Size Counter-interval Collector-list
(in secs)
2/1 10000 128 0 1
2/2 10000 128 0 1
2/3 8192 128 0 2
2/4 12001 128 0 2
All 4 out of 4 Total Num of sflow port entries displayed
Use the data in the following table to use the sflow sampling-rate and show sflow interface commands.
Variable |
Value |
<1024–1000000> |
Configures the packet sampling rate on a port. The default value is 0 (disabled). To configure the default value, enter default sflow sampling-rate. |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
