Configure the maximum header size on a single port or multiple ports.
You must globally enable sFlow.
For ports 1/1 to 1/10, configure the maximum header size, and then verify the configuration.
Switch:1(config-if)#interface gigabitethernet 1/1-1/10
Switch:1(config-if)#sflow max-header-size 255
Switch:1(config-if)#show sflow interface 1/1-1/10
sFlow Port Configuration Info
Port Packet-Sample-Rate Max-Header-Size Counter-interval Collector-list
(in secs)
1/1 0 255 525 1,2
1/2 0 255 525 1,2
1/3 0 255 525 1,2
1/4 0 255 525 1,2
1/5 0 255 525 1,2
1/6 0 255 525 1,2
1/7 0 255 525 1,2
1/8 0 255 525 1,2
1/9 0 255 525 1,2
1/10 0 255 525 1,2
Use the data in the following table to use the max-header-size command.
Variable |
Value |
<64–256> |
Identifies the maximum number of bytes to be copied from the sampled packet. Default 128 bytes. |
