The Extreme-Dynamic-Client-Assignments Vendor Specific Attribute (VSA) is a RADIUS VSA for dynamic VLAN and Private VLAN (PVLAN) creation. You can also configure VLAN parameters, such as VLAN name, I-SID to VLAN association, I-SID name, and I-SID to dynamic VRF association.
You can use Extreme-Dynamic-Config RADIUS VSA to configure the VLAN-based features.
Platform VLAN manual
configuration—This maps the Extreme-Dynamic-Client-Assignments
Radius VSA without create
. Only the options used to define the existing
functionality of mapping clients to VLAN on regular ports or vlan:isid on
flex-uni ports are used—Primary VLAN (PV), Virtual Network Identifier (VNI),
and Egress VLAN (EV). The Secondary VLAN (SV), VLAN Name (VN), and VNIN
attributes for dynamic VLAN are ignored.
Regular VLAN
configuration—This maps the VSA with the option create=vlan
. The
Multiple Spanning Tree Protocol (MSTP) instance is 0. When platform VLAN is
dynamically created, all VLAN parameters are also dynamically applied; a
static VLAN setting is not allowed. Dynamic platform VLANs and dynamic
I-SIDs names exist as long as EAP clients reference them. If clients do not
use them, then they are deleted and are not saved in the configuration file.
PVLAN
configuration—This maps with the usage of
Extreme-Dynamic-Client-Assignments Radius VSA with the create=pvlan
option. The EAP and Private VLANs on regular ports are not supported. But
they are supported on flex-uni ports. The MSTP instance is 0. When you
dynamically create a private VLAN, all VLAN parameters are also dynamically
created; a static VLAN setting is not allowed. Dynamic PVLANs and dynamic
Use the information in the following tables and this string format to create a dynamic VLAN:
create=vlan|pvlan,pv=Primary
VLANID, sv=secondary VLANID, vni=ISID, ev=EGRESS-VLAN-tag, vn=vlan-name,
vnin=isid-name, mvni=ISID
If ev
is missing, it
will default to 0
You can also use U
or T
(case-sensitive). When ev
is set to U
, it is untagged or
0
. When
ev
is set to T
, it takes the value of
pv
or tagged. If
pv
is not
specified, then an error occurs and the VSA is ignored.
Option | Description |
create=vlan |
pvlan
If Note the following two examples:
This option is ignored on DvR Leafs. |
pv=Primary VLANID
The platform VLAN that the client is assigned. This option is valid for any combination of the |
sv=Secondary
VLANID |
This option is only valid for a private VLAN and if the |
vni=ISID
If you did not use The |
ev=EGRESS-VLAN-tag
Use this option on regular ports to tag or untag the egress for the PV. Use this option on flex-uni ports as |
vn=Vlan name
Valid only if you use |
vnin=ISID name
mvni=ISID |
Use this option to configure IP Multicast config-lite for Fabric
Connect functionality. This option configures the I-SID value for
the Layer 3 VSN VLAN and enables SPB Multicast on the VLAN. You can
associate For information about IP Multicast config-lite for Fabric Connect, see IP Multicast config-lite for Fabric Connect. |
Port Type | RADIUS Attribute | Extreme-Dynamic-Client-Assignments Radius VSA | Comment |
Regular port |
Tunnel Private GroupID |
Without
This adds the port to the primary VLAN; tag is the port tag. |
Without
Untagged: Tagged: This adds the port to the primary VLAN; The VLAN egress tag is
dictated by the |
Not Supported |
Flex-Uni ports |
Without create .
Untagged: Tagged: A S-UNI is created, either MAC-based or regular, depending on
MHMV/MHSA setting; uses |
Supported by the same combination for FA VLAN:ISID |
Without create .
MHMV/MHSA setting; uses auto configured |
Not supported |
Not supported |
The dynamic VLAN is deleted after you disconnect all of the clients across the Extensible Authentication Protocol (EAP) ports. The port is removed when the last client is disconnected and the saved I-SID name is restored.
You cannot delete a static VLAN if EAP ports are assigned to it. However, you can delete the VLAN if you have added EAP FlexUNI ports to it. This flushes all MAC addresses and deletes any Non-EAP (NEAP) sessions. The MAC address is re-learned in I-SID and a new RADIUS authentication can now create a dynamic VLAN. For EAP sessions, the session moves to the re-authentication state, and the new RADIUS authentication can create a dynamic VLAN.
In Multiple Host Multiple VLAN (MHMV), if there are multiple assignments received for one session, the rule is to process only the last one and ignore the rest.
