Configure the required SPBM and IS-IS infrastructure, which includes the creation of SPBM B-VLANs.
Create the C-VLANs and add slots/ports.
Enable IP Multicast over Fabric Connect globally.
If no IP interface exists on the VLAN, create one. The IP interface must be the same subnet as the IGMP hosts that connect to the VLAN.
Use this procedure to configure IP Multicast over Fabric Connect within the GRT. The default is disabled.
You cannot enable IP PIM when IP Multicast over Fabric Connect is enabled on the VLAN.
The switch only supports IPv4 addresses with IP Multicast over Fabric Connect.
enable
configure terminal
interface vlan <1–4059>
ip address <A.B.C.D/X>
ip spb-multicast enable
After you configure ip spb-multicast enable, you cannot enable IGMP, IGMP Snooping, or IGMP proxy on the interface. If you try to enable IGMP Snooping or proxy on any interface where IP Multicast over Fabric Connect is enabled, an error message displays.
When you configure ip spb-multicast enable on the Controller node of a DvR domain, the configuration is automatically pushed to the Leaf nodes within the domain.
show ip igmp interface
If routed-spb displays under MODE, IP Multicast over Fabric Connect within the GRT is properly enabled on the VLAN.
Enable IP Multicast over Fabric Connect within the GRT:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface vlan 500 Switch:1(config-if)#ip address 192.0.2.1 255.255.255.0 Switch:1(config-if)#ip spb-multicast enable
Switch:1#show ip igmp interface
Igmp Interface - GlobalRouter
QUERY OPER QUERY WRONG LASTMEM
IF INTVL STATUS VERS. VERS QUERIER MAXRSPT QUERY JOINS ROBUST QUERY MODE L2ISID SCOPE
ISID
V500 125 active 2 2 0.0.0.0 100 0 0 2 10 routed-spb
V2000 125 inact 2 2 0.0.0.0 100 0 0 2 10
1 out of 1 entries displayed
