The following table defines parameters for the interface vlan command.
Variable |
Value |
<1-4059> |
Specifies the VLAN ID. |
The following table defines parameters for the interface GigabitEthernet command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
The following table defines parameters for the ip address command.
Variable |
Value |
<A.B.C.D/X> |
Specifies the address and mask. |
