Configure multicast stream limitation to limit the number of concurrent multicast streams on the port. Limit the number of streams to protect the bandwidth on a specific port and control access to multicast streams.
  1. On the Device Physical View tab, select a port.
  2. In the navigation pane, expand Configuration > Edit > Port.
  3. Select IP.
  4. Select the IGMP tab.
  5. In StreamLimitEnable, select enable.
  6. Configure the maximum number of streams.
  7. Select Apply.
