Configure multicast stream limitation members on ports of the specified interface to configure the maximum number of streams on the interface.
You can configure IGMP on a VRF instance the same way you configure the Global Router except that you must first launch the appropriate VRF context.
  1. In the navigation pane, expand Configuration > IP.
  2. Select IGMP.
  3. Select the StreamLimit Members tab.
  4. Select Insert.
  5. Type the number of the VLAN to which you want to add a member or select Vlan to select an ID from the list.
  6. Type the number of the slot and port that you want to add as a member or select Port, and then select a port from the graphic display. If your platform supports channelization for 40 Gbps ports and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.
    Important
    Important
    You must select one of the ports in the VLAN that you selected in step 4.
  7. Type a maximum number of streams or accept the default of 4.
  8. Select Insert.
StreamLimit Members Field Descriptions
Use the data in the following table to use the StreamLimit Members tab.
Name
Description
IfIndex
Displays the ID of the VLAN.
Port
Lists each slot and port number for this interface with stream limitation enabled.
Identifies the slot and port in one of the following formats:
  • a single slot and port (slot/port)
  • a range of slots and ports (slot/port-slot/port)
  • a series of slots and ports (slot/port,slot/port,slot/port)
  • all ports on the same slot (slot/all)
  • all ports on the switch (all)
MaxStreams
Configures the maximum number of allowed streams for this specific port. The number of allowed streams cannot exceed the maximum number for the interface. The range is from 0–65535 and the default is 4.
NumStreams
Displays the current number of streams received on this interface. This value is a read-only value.
