Use this procedure to display BFD session information for IPv4 neighbors.
The following example displays BFD session information for an IPv4 neighbor.
Switch:1>show ip bfd neighbors
BFD Session - GlobalRouter
MY_DISC YOUR_DISC NEXT_HOP STATE MULTI MIN_TX MIN_RX ACT_TX DETECT_TIME REMOTE_STATE APP RUN
1 0 192.0.2.11 Down 3 200 200 1000 600 Down O
1 out of 1 BFD session displayed
APP and RUN Legend:
B=BGP, O=OSPF, S=Static Route
The following table defines parameters for the show ip bfd neighbors command.
Variable |
Value |
{A.B.C.D} |
Specifies the next-hop IP address in the format a.b.c.d. |
vrf WORD<1-16> |
Specifies a VRF instance by name (the string length ranges from 1–16 characters). |
vrfids WORD<0-512> |
Specifies a range of VRFs by ID number (the ID ranges from 0–512). |
