BFD for IPv6 interfaces is a demonstration feature on some products. For more information about feature support, see Fabric Engine and VOSS Feature Matrix.
Use the following procedure to display BFD configuration on an IPv6 interface.
The following example displays port configuration information for BFD.
Switch:1>show ipv6 bfd interfaces gigabitethernet 1/3
Port Bfd
PORT STATUS MIN_RX INTERVAL MULTIPLIER VRF-ID
1/3 enable 200 200 3 0
The following table defines parameters for the show ip bfd interfaces command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
<1-4059> |
vrf WORD<1-16> |
Specifies a VRF instance by VRF name. |
vrfids WORD<0-512> |
Specifies a VRF or range of VRFs by ID. |
