Configure ACE Actions
Configure ACE actions to determine the process that occurs after a packet matches (or does not match) an ACE. Use debug actions (flags) to use filters for troubleshooting and monitoring procedures.
The ACE exists.
- Select Advanced Filters (ACE/ACLs).
- Select the ACL tab.
- Select the appropriate ACL.
- Select ACE.
- Select an AceId.
- Select Action.
- Configure the actions as required, and then select Apply.
Action Field Descriptions
Use the data in the following table to use the Action tab.
![Note](images/note.png)
The table lists the options for both Security ACEs and QoS ACEs. Dependent upon the ACE, the system displays different options on the EDM interface.
Name |
Description |
AclId |
Specifies the ACL ID. |
AceId |
Specifies the ACE ID. |
Mode |
Configures the action mode for security ACEs. The default value is deny. |
RemarkDscp |
Specifies the new Per-Hop Behavior (PHB) for matching packets: phbcs0, phbcs1, phbaf11, phbaf12, phbaf13, phbcs2, phbaf21, phbaf22, phbaf23, phbcs3, phbaf31, phbaf32, phbaf33, phbcs4, phbaf41, phbaf42, phbaf43, phbcs5, phbef, phbcs6, phbcs7. This action is a QoS action. |
RemarkDot1Priority |
Specifies the new 802.1 priority bit for matching packets: zero, one, two, three, four, five, six, or seven. This action is a QoS action. Note:
This does not apply to IPv6 filtering. |
InternalQoS |
This variable is a QoS action. The default value is 1. Note:
RedirectNextHop |
Specifies the next-hop IPv4 address (a.b.c.d) or IPv6 address (aaaa:bbbb:cccc:dddd:eeee:ffff:gggg:hhhh) for redirect mode. Applies to ingress ACLs (routed and Layer 2 packets). |
Count |
Enables the ability to count matching packets. Use this parameter with either a security or QoS ACE. The default is disabled. |
DstPortList |
Configures mirroring to a destination port or ports. This action is a security action. |
DstMltId |
Configures mirroring to a destination MLT. This action is a security action. |
MonitoringIsidOffset |
Configures the monitoring I-SID offset value. The offset ID is mapped to the actual monitor I-SID value to which the packets are mirrored. |
MirroringQoS |
Defines the Quality of Service (QoS) profiles for the mirrored packet into monitoring I-SID. |
