Configure ACE ARP entries
Use ACE Address Resolution Protocol (ARP) entries so that the filter looks for ARP request or response packets.
  • The ACL exists.
  • The ACE exists.
  1. In the navigation pane, expand Configuration > Security > Data Path.
  2. Select Advanced Filters (ACE/ACLs).
  3. Select the ACL tab.
  4. Select a parameter for the appropriate ACL.
  5. Select ACE.
  6. Select a parameter for the appropriate ACE.
  7. Select Arp.
  8. Select Insert.
  9. Select ARP request or response.
  10. Select Insert.
ARP Field Descriptions
Use the data in the following table to use the ARP tab.
Name
Description
AclId
Specifies the ACL ID.
AceId
Specifies the ACE ID.
Type
Specifies the ACE ARP operation. The only option is operation.
Oper
Specifies the operator for the ACE ARP operation. The only option is eq (equal).
Value
Specifies the ARP packet type. Valid options are arpRequest and arpResponse.
