Use this task to view the default topology IP address for a Segmented Management Instance.
  1. In the navigation pane, expand Configuration > Edit.
  2. Select Mgmt Instance.
  3. Select Mgmt.
  4. Select the TopologyIp tab.
TopologyIp Field Descriptions
Use the data in the following table to use the TopologyIp tab.
Name
Description
AddrType
Shows the IP address type for the topology IP.
Addr
Shows the IP address for the topology IP.
InterfaceName
Shows the interface name of the identified interface for the topology IP.
InstanceId
Specifies the interface instance for the topology IP.
