Enable the SNMP agent process to generate authentication-failure traps.
  1. In the navigation pane, expand Configuration > Serviceability > Diagnostics.
  2. Select General.
  3. Select the Error tab.
  4. Select AuthenticationTraps.
  5. Select Apply.
Error Field Descriptions
Use the data in the following table to use the Error tab.
Name
Description
AuthenticationTraps
Enables or disables the sending of traps after an error occurs. The default is disabled.
LastErrorCode
Specifies the last reported error code.
LastErrorSeverity
Specifies the last reported error severity:
0= Informative Information
1= Warning Condition
2= Error Condition
3= Manufacturing Information
4= Fatal Condition
