This command displays information for DDI transceivers.
Transceiver support differs across hardware platforms. For information about supported parts, see Extreme Optics website.
Switch:1#show pluggable-optical-modules temperature
Pluggable Optical Module Temperature(C)
PORT LOW_ALARM LOW_WARN ACTUAL HIGH_WARN HIGH_ALARM THRESHOLD
NUM THRESHOLD THRESHOLD VALUE THRESHOLD THRESHOLD STATUS
1/2 7.0 1.1250 65.2539 0.0 3.0156 Low Alarm
1/3 7.0 1.1250 65.2539 0.0 3.0156 Low Alarm
1/9 7.0625 0.0 65.2539 0.0 3.0156 Low Alarm
1/15 7.0625 0.0 65.2539 0.0 3.0156 Low Alarm
2/1 7.0625 0.0 65.2539 0.0 3.0156 Low Alarm
2/2 7.0625 0.0 65.2539 0.0 3.0156 Low Alarm
2/3 7.0625 0.0 65.2539 0.0 3.0156 Low Alarm
Use the data in the following table to use the show pluggable-optical-modules temperature command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
