Display MSTP MSTI Information
Display MSTP MSTI information to ensure the feature is configured correctly for your network.
Display MSTI information:
Switch:1>
show spanning-tree mstp msti config 62
                              MSTP Instance Status
Instance Id                     : 62
Msti Bridge Regional Root       : 80:00:00:15:e8:9e:10:01
Msti Bridge Priority            : 32768 (0x8000)
Msti Root Cost                  : 0
Msti Root Port                  : cpp
Msti Instance Vlan Mapped       :
Msti Instance Vlan Mapped2k     :
Msti Instance Vlan Mapped3k     :
Msti Instance Vlan Mapped4k     : 4000
                                                  Switch(config)#
show spanning-tree mstp msti port statistics 1/1
                  MSTP Instance-specific Per-Port Statistics
Port Number                  : 1/1
Instance Id                  : 1
Msti Port Fwd Transitions    : 0
Msti Port  Received BPDUs    : 0
Msti Port Transmitted BPDUs  : 0
Msti Port Invalid BPDUs Rcvd : 0
Use the data in the following table to use the show spanning-tree mstp msti command.
| Variable | Value |
| config [<1-63>] | Shows the configuration for one or all MSTP instance IDs. |
| port | Shows the configuration, role, or statistics information of a MSTP port.
