Perform the following procedure to display the MSTP, CIST port, and MSTI port information maintained by every port of the common spanning tree.
show spanning-tree mstp port role [{sub-port]][,...][slot/all][all]}]
If your platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.
Display the MSTP port information:
Switch:1>
show spanning-tree mstp port role 1/3
                           CIST Port Roles and States
Port-Index  Port-Role    Port-State   PortSTPStatus  PortOperStatus
1/3         Disabled    Discarding      Enabled        Disabled
