Configure the DHCP relay behavior on the interface.
You can configure only one relay for a VLAN, regardless of how many addresses are configured on that VLAN. The default address is the smallest address configured. If the relay is a VRRP address, the default value is the first VRRP address configured.
Configure the maximum hop count:
Switch:1(config-if)#ipv6 dhcp-relay max-hop 30
Disable the remote ID:
Switch:1(config-if)#no ipv6 dhcp-relay remote-id
Use the data in the following table to use the ipv6 dhcp-relay command.
Variable |
Value |
max-hop <1–32> |
Specifies the maximum number of hops a DHCP packet can take from the DHCP client to the DHCP server. The default is 32. |
remote-id |
Enables the relay agent to add information about the relay to DHCPv6 messages before relaying the messages to the DHCP server. The default is disabled |
Use the data in the following table to use the interface command.
Variable |
Value |
<1-4059> |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
