View DHCP Relay information to display the current configuration for the forwarding path and the interface configuration.
Not all parameters are available in non-default VRFs.
Switch:1(config-if)#show ipv6 dhcp-relay fwd-path ================================================================================ DHCPv6 Fwd-path - GlobalRouter ================================================================================ INTERFACE SERVER ENABLE -------------------------------------------------------------------------------- 1111:0:0:0:0:0:0:1111 1234:0:0:0:0:0:0:1234 enable
Use the information in the following table to help you use the show ipv6 dhcp-relay command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
vlan<1-4059> |
vrf WORD<1–16> |
Specifies the VRF name. |
vrfids WORD<0–512> |
Specifies the VRF ID. |
