Trigger a Loopback Test (LBM)
Use this procedure to trigger a loopback test.
The LBM packet is often compared to ping. An MEP transmits the loopback message to an intermediate or endpoint within a domain for the purpose of fault verification. This can be used to check the ability of the network to forward different sized frames.
            You must have a MEP that is associated with a B-VLAN.
loopback WORD<0–22> WORD<0–22> <1–8191> <0x00:0x00:0x00:0x00:0x00:0x00> [burst-count <1–200>] [data-tlv-size <0–400>] [frame-size <64–1500>] [interframe-interval <msecs>] [priority <0–7>] [source-mode {nodal| smltVirtual}][testfill-pattern <all-zero|all-zero-crc|pseudo-random-bit-sequence|pseudo-random-bit-sequence-crc>] [time-out <1–10>]
Switch:1# loopback md1 4001 13 00:14:0D:A2:B3:DF burst-count 10 priority 3 time-out 5
Result of LBM from mep: spbm.bvlan1000.8 to MAC address: 00:66:00:66:00:66 : Sequence number of the first LBM is 150404162 The total number of LBMs sent out is 1 The number of LBRs received is 1 The number of LBRs lost is 0 The percentage of LBMs lost is 0.00% The RTT Min is 15071 microsecs, Max is 15071 microsecs, Average is 15071.00 microsecs The Standard Deviation of RTT is 0.00 microsecs
The following table defines parameters for the loopback command.
| Variable | Value |
| WORD<0–22> | The first parameter, specifies the MD name. |
| WORD<0–22> | The second parameter, specifies the MA name. |
| <1–8191> | Specifies the MEP ID. |
| <0x00:0x00:0x00:0x00:0x00:0x00> | Specifies the remote MAC address to reach the MEP/MIP. |
| burst-count <1–200> | Specifies the burst-count. |
| data-tlv-size <0–400> | Specifies the data TLV size. |
| frame-size <64–1500> | Specifies the frame-size. The default is 0. |
| priority <0–7> | Specifies the priority. The default is 7. |
| source-mode{nodal | smltVirtual}]| Note:
                                     Exception: smltVirtual is not supported on 5320 Series. | Specifies the source mode:
 The default is nodal. |
| testfill-pattern {all-zero|all-zero-crc|pseudo-random-bit-sequence|pseudo-random-bit-sequence-crc} | Specifies the testfill pattern:
 A cyclic redundancy check is a code that detects errors. The default is 1: all-zero. |
| time-out <1–10> | Specifies the time-out interval in seconds. The default is 3. |
