If you enable the cfm spbm enable command, you cannot assign a MEP/MIP level to an individual SPBM B-VLAN or configure CFM MD maintenance levels individually.
Enables the global CFM MEP and MIPs for all SPBM B-VLANs.
    enable
    configure terminal
  2. Enable simplified CFM configuration for SPBM VLANs:
    cfm spbm enable
  3. Enter the CFM SPBM level:
    cfm spbm level <0–7>
  4. Enter the CFM SPBM MEPID level:
    cfm spbm mepid <1–8191>
Switch:1(config)# cfm spbm level 7
Switch:1(config)# cfm spbm mepid 12
Switch:1(config)# cfm spbm enable
The following table defines parameters for the simplified CFM commands.
Variable
Value
spbm level <0–7>
Configures the maintenance level for every CFM SPBM MEP and MIP level on all SPBM B-VLANs. The default is 4.
mepid <1–8191>
Assigns a global MEP ID for all CFM SPBM MEPs. The default is 1.
no cfm spbm enable
Disables global configuration of CFM SPBM MEP and MIP levels on all SPBM B-VLANs.
default cfm spbm level
Returns maintenance level to default for all CFM SPBM MEP and MIP level on all SPBM B-VLANs.
default cfm spbm mepid
Returns MEP ID for all CFM SPBM MEPs to default.
show cfm spbm
Displays the global CFM MEP configuration for SPBM B-VLANs.
