Configure a tagged port to discard all untagged packets so that the frame is not classified into the default VLAN for the port.
  1. Enter GigabitEthernet Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
  2. Configure a tagged port to discard untagged frames:
    untagged-frames-discard [port {slot/port[/sub-port][-slot/port[/sub-port]][,...]}]
  3. Discard a tagged frame on an untagged port:
    tagged-frames-discard [port {slot/port[/sub-port][-slot/port[/sub-port]][,...]}] enable
  4. Untag the default VLAN on a tagged port:
    untag-port-default-vlan [port {slot/port[/sub-port][-slot/port[/sub-port]][,...]}] enable
Switch(config-if)#untagged-frames-discard port 1/1
Switch(config-if)#tagged-frames-discard port 1/1 enable
Switch(config-if)#untag-port-default-vlan port 1/2 enable
Use the data in the following table to use optional parameters with the untagged-frames-discard command.
Variable
Value
Identifies the slot and port in one of the following formats:
  • a single slot and port (slot/port)
  • a range of slots and ports (slot/port-slot/port)
  • a series of slots and ports (slot/port,slot/port,slot/port)
  • all ports on the same slot (slot/all)
  • all ports on the switch (all)
