Show DHCP Relay Information
Perform this procedure to show relay information about DHCP routes and counters.
For scaling information on DHCP Relay forwarding (IPv4 or IPv6), see Fabric Engine Release Notes.
Display information for all DHCP relay interfaces:
Switch:1>show ip dhcp-relay interface
Port Dhcp
PORT VRF MAX MIN ALWAYS CIRCUIT REMOTE TRUST
NUM NAME ENABLE HOP SEC MODE BCAST ID ID CIRC
1/5 GlobalRouter false 4 0 dhcp & bootp false false false false
Vlan Dhcp
VLAN VRF MAX MIN ALWAYS CIRCUIT REMOTE TRUST SMART
ID NAME ENABLE HOP SEC MODE BCAST ID ID CIRC RELAY
2 GlobalRouter false 4 0 dhcp & bootp false false false false disabled
5 GlobalRouter true 4 0 dhcp & bootp false false false false disabled
All 2 out of 2 of Vlan Dhcp Entries displayed
Variable definitions
Use the data in the following table to use the show ip dhcp-relay command.
Variable |
Value |
vrf WORD<1-16> |
The name of the VRF. |
vrfids WORD<0-512> |
The ID of the VRF. The value is an integer in the range of 0–512. |
Use the data in the following table to use the show ip dhcp-relay interface command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
[vlan <1-4059>] |
[vrf WORD<1-16>] |
Specifies the name of the VRF. |
[vrfids WORD<0-512>] |
Specifies the ID of the VRF. The value is an integer from 0– 512. |
