Perform this procedure to remove a specific configuration file from Fabric IPsec Gateway Virtual Machine (VM).
Remove configuration file "test" from Fabric IPsec Gateway VM:Switch:1> enable Switch:1# virtual-service figw console Connected to domain figw Escape character is ^Y <cr> FIGW> remove test
The following table defines parameters for the remove command.
Variable | Value |
WORD <1-255> | Specifies the configuration file name that the system removes from Fabric IPsec Gateway VM. |
