Perform this procedure to save the current configuration on Fabric IPsec Gateway Virtual Machine (VM) to a specific file.
  1. Enter Fabric IPsec Gateway Configuration mode:
    enable
    virtual-service WORD<1-128> console
    Type CTRL+Y to exit the console.
  2. Save configuration to the default configuration file:
    save config [-y]
  3. Save configuration to a specific file in the Fabric IPsec Gateway VM.
    save config file WORD <1-255> [-y]
Save the Fabric IPsec Gateway configuration to file "test":
Switch:1> enable
Switch:1# virtual-service figw console
Connected to domain figw
Escape character is ^Y
  <cr>
FIGW>save config file test.txt
File already exists, do you want to overwrite [y/n]: y
Save the Fabric IPsec Gateway configuration to file "test", forcing the switch to overwrite the file without confirmation:
Switch:1> enable
  <cr>
FIGW> save config file test.txt -y
The following table defines parameters for the save config command.
Variable Value
file WORD <1-255> Specifies the name of file to save the configuration of the Fabric IPsec Gateway VM.
-y
Forces the switch to overwrite the configuration file without confirmation.
