Use the following commands to display IGMP information.
enable
show ip igmp interface [gigabitethernet {sub-port]][,...][slot/all][all]}][vlan <1-4059>][vrf WORD<1–16>][vrfids WORD<0–512>]
Ensure that the ouput displays routed-spb under MODE.
show ip igmp cache [vrf WORD<1–16>][vrfids WORD<0–512>]
show ip igmp group [count][group {A.B.C.D}][member-subnet default|{A.B.C.D/X}][vrf WORD<1–16>][vrfids WORD<0–512>]
show ip igmp sender [count][group {A.B.C.D}][member-subnet default|{A.B.C.D/X}][vrf WORD<1–16>][vrfids WORD<0–512>]
Display IGMP information for IP multicast over Fabric Connect within the GRT:
Switch:1#show ip igmp interface vrf l3vsn-100
Igmp Interface - VRF l3vsn-100
QUERY OPER QUERY WRONG LASTMEM SCOPE
IF INTVL STATUS VERS. VERS QUERIER MAXRSPT QUERY JOINS ROBUST QUERY MODE L2ISID ISID
V10 125 inact 2 2 0.0.0.0 100 0 0 2 10 routed-spb 0 100
Switch:1#show ip igmp interface vlan 2
Vlan Ip Igmp
VLAN QUERY QUERY ROBUST VERSION LAST PROXY SNOOP SNOOP SSM UPnP FAST FAST
ID INTVL MAX MEMB SNOOP ENABLE ORIGIN SNOOP FILTER LEAVE LEAVE
RESP QUERY ENABLE ENABLE ENABLE ENABLE PORTS
2 125 100 2 2 10 false false RADIUS false true false
VLAN SNOOP SNOOP DYNAMIC COMPATIBILITY EXPLICIT UPnP
ID QUERIER QUERIER DOWNGRADE MODE HOSTS FILTER
ENABLE ADDRESS VERSION TRACKING ADDRESS
2 false 0.0.0.0 enable disable disable 192.0.2.3/24
Switch:1# show ip igmp sender
IGMP Sender - GlobalRouter
PORT/
GRPADDR IFINDEX MEMBER MLT STATE L2ISID SCOPEISID DATAISID
224.1.1.4 Vlan 10 192.2.0.1 1/18/1 NOTFILTERED 0 10010 16000001
224.1.1.4 Vlan 10 192.2.0.1 1/18/1 NOTFILTERED 0 10010 16000004
224.1.1.6 Vlan 10 192.2.0.1 1/18/1 FILTERED 0 10010 16000010
224.1.1.7 Vlan 10 192.2.0.1 1/18/1 FILTERED 0 10010 16000009
224.1.1.8 Vlan 10 192.2.0.1 1/18/1 NOTFILTERED 0 10010 210
5 out of 5 entries displayed
Switch:1#show ip igmp group
Igmp Group - GlobalRouter
GRPADDR INPORT MEMBER EXPIRATION TYPE L2ISID
224.5.2.1 V701-1/4 62.0.1.1 214 Dynamic 40400
224.5.2.2 V702-1/4 62.0.2.1 221 Dynamic 40400
224.5.2.3 V703-1/4 62.0.3.1 217 Dynamic 40400
224.5.2.4 V704-1/4 62.0.4.1 223 Dynamic 40400
4 out of 4 group Receivers displayed
Total number of unique groups 2
