Variable definitions
The following table defines parameters for the show isis spbm ip-multicast-route command.
Variable
Value
all
Displays all IP Multicast over Fabric Connect route information.
detail
Displays detailed IP Multicast over Fabric Connect route information.
group {A.B.C.D} source {A.B.C.D} [source-beb WORD<0–255>]
Displays information on the group IP address for the IP Multicast over Fabric Connect route. If you select source it will also display the source IP address.
Specifies the source BEB name.
vlan
Displays IP Multicast over Fabric Connect route information by VLAN.
vrf
Displays IP Multicast over Fabric Connect route information by VRF.
vsn-isid
Displays IP Multicast over Fabric Connect route information by I-SID.
The following table defines parameters for the show isis spb-mcast-summary command.
Variable
Value
count
Displays the total number of SPB multicast entries.
host-name
Displays the IP Multicast over Fabric Connect summary for a given host-name.
lspid
<xxxx.xxxx.xxxx.xx-xx>
Displays the IP Multicast over Fabric Connect summary for a given LSP ID.
