Perform this procedure to configure scheduled time intervals during which the switch will operate in low power state. This time interval can be for a week, weekend, or individual days.
![Note](images/note.png)
You can configure a maximum of 84 entries in the Energy Saver schedule.
If you have previously enabled Energy Saver globally, you must disable it globally before creating a schedule.
If you have previously enabled Efficiency Mode, you must disable it before creating a schedule. You cannot change the default Efficiency Mode schedule entries when Efficiency Mode is enabled.
You must enable Energy Saver on every port affected by the schedule.
Switch:1>enable Switch:1# configure terminal Switch:1(config)#energy-saver schedule weekend 0735 activate Switch:1(config)#energy-saver schedule monday 0600 deactivate
What to do next
Enable Energy Saver globally.
The following table defines parameters for the energy-saver schedule command.
Variable |
Value |
{activate | deactivate} |
Activates or deactivates the scheduled event. |
<hhmm> |
Specifies the hour and minutes to enable Energy Saver feature on the switch. |
{friday | monday | saturday | sunday | thursday | tuesday | wednesday | weekday | weekend} |
Specifies the day(s) to enable Energy Saver feature on the switch. |
