View PIM-SM neighbor parameters to troubleshoot connection problems or review the configuration.
  1. In the navigation pane, expand Configuration > IP.
  2. Select PIM.
  3. Select the Neighbors tab.
Neighbors Field Descriptions
Use the descriptions in the following table to use the Neighbors tab.
Name
Description
Address
Shows the IP address of the PIM neighbor.
IfIndex
Shows the slot and port number or VLAN ID of the interface used to reach this PIM neighbor.
UpTime
Shows the time since this neighbor became a neighbor of the local router.
ExpiryTime
Shows the time remaining before the neighbor expires.
