Quality Summary
This frame shows four graphs with the following information:
EQS Evolution
Historical graph showing the evolution of the EQS for all flows, and for the Top, High, Medium and Low flows. The covered period and the granularity of the data depend on the time span (see "Frames and Timing"): it can be three hours of per-minute information, if the time span is the minute (then you can scroll the past hours with the horizontal scroll bar at the bottom of the graph), or it can be the last three days of hourly averaged information, if the time span is the hour.
Site Overview
Pie chart showing the number of Sites (and the percentage of the total they represent):
• with an EQS higher or equal to 9 (in green),
• with an EQS between 6 and 9 (in yellow),
• with an EQS lower than 6 (in red),
• where the EQS could not be computed (none, in grey).
Application Groups by EQS
• Bar graph showing the Top 10 Application Groups (i.e. the 10 AGs with the best quality) sorted by decreasing quality (the best AG is displayed in the first bar on the left), with their EQS values displayed both as a number (between 0 and 10 with two decimals) and as a colored bar (the height of the bar indicates the value on the vertical axis and the color can take any hue between green (EQS = 10) and red (EQS = 0)).
• By clicking on Worst 10 at the top of the bar graph, the 10 worst Application Groups are displayed, sorted by increasing quality (the worst AG is displayed in the first bar on the left), with their EQS values.
Sites by EQS
• This bar graph shows the Top 10 Sites (i.e. the 10 Sites with the best quality) sorted by decreasing quality (the best Site is displayed in the first bar on the left), with their EQS values displayed both as a number (between 0 and 10 with two decimals) and as a colored bar (the height of the bar indicates the value on the vertical axis and the color can take any hue between green (EQS = 10) and red (EQS = 0)).
• By clicking on Worst 10 at the top of the bar graph, the 10 worst Sites are displayed, sorted by increasing quality (the worst Site is displayed in the first bar on the left), with their EQS values.
By clicking on a bar, a new window opens and shows detailed information for the selected Site.
