SaaS Applications over the last Hours/Days
This view displays the list of the most common SaaS applications discovered on the network over the selected period.
After you have defined the Time Range (Last hour/4 hours/12 hours/ 24 hours and last 7 days) of the displayed list, this list is automatically refreshed and the number of SaaS applications specified in the dashboard header is updated.
• The displayed SaaS Applications have been discovered by the appliance during the last 24 hours (current example).
You can view the description of each application by hovering over its name with your mouse. Note that SaaS applications associated with subnet information in the SaaS dictionary are identified through the "(identification on first packet)" label at the end of their respective descriptions.
Note: SaaS applications listed in black have been recognized and provisioned while applications displayed in blue remain to be defined and optionally assigned to an Application Group. See the procedure below.
• The second column specifies the number of Sites linked to each SaaS Application.
• The approximative Volume value is given for each SaaS application for all the Sites of the Domain.
Provisioning a SaaS Application
1 From the dashboard list, click a SaaS application name displayed in blue.
2 You may keep the application name by default or enter a new Name.
3 Keep the Enabled administrative state checked (default) to activate the application.
4 From the stack of already defined Application Groups, select one AG the current application will be assigned to.
5 Hit Create.
The original SaaS Application name is now displayed in black on the dashboard.
The SaaS Application appears in the Applications window under its new name (if you changed its original name); see "Configuring Applications".
Also see "Creating new applications"and "Creating customized SaaS applications".
