The following table shows the default settings starting with version 31.6, and shows any changes that have been made to these settings and in what version these changes were made.
| Feature | 31.6 and later | 32.4 and later |
| 1G behavior in 10G ports (5420 and 5520 series switches) | Autoneg OFF for port when 1G optic is inserted in a 10G port | |
| Account Lockout | After 3 consecutive login failures, account is locked for 5 minutes. a | |
| Auto-Discovery for Universal Hardware | Enabled. | |
| AVB | Disabled. | |
| BFD Strict Session Protection | Disabled. | |
| BGP | Disabled. | |
| Bluetooth | Enabled. | |
| BOOTP Relay | Disabled. | |
| CDP | Enabled. | |
| Configuration auto save | Disabled. | |
| Clear-flow | Disabled. | |
| Diagnostics | Admin level privileges required to show diagnostics.a | |
| DHCP | Disabled. | |
| DNS Cache Resolver and Analytics | Disabled. | |
| IPFIX | Disabled. | |
| IP NAT | Disabled. | |
| EAPS | Disabled. | |
| EDP | Enabled. | |
| ELRP | Disabled. | |
| ESRP | Disabled. | |
| Extended Edge Switching (VPEX) | Disabled. | |
| ExtremeCloud IQ | Enabled | |
| FEC | Enabled on Native 25Gb ports. | |
| Identity Management | Disabled. | |
| IGMP | Enabled, set to IGMPv2 compatibility mode. | |
| IGMP Snooping | Enabled. | |
| Image Integrity Check | Disabled. | |
| IP Route Compression | Enabled. | |
| ISIS | Disabled. | |
| LLDP | Enabled. | |
| Log | Admin level privileges required to show log. a | |
| Logging memory buffer | Generate an event when the logging memory buffer exceeds 90% of capacity.a | |
| MAC Security | Disabled. | |
| MLD | Disabled. | |
| MLD Snooping | Disabled. | |
| MPLS | Disabled. | |
| MSRP | Disabled. | |
| MSTP | Enabled. | |
| NetLogin | All types of authentication are disabled. | |
| NTP | Disabled. | |
| ONEPolicy | Disabled. | |
| Policy rule model | Hierarchical (Unless upgrading from 30.5 with a saved configuration set to access list.) | |
| OpenFlow | Disabled. | |
| OSPF | Disabled. | |
| OVSDB | Disabled. | |
| Passwords | Plain text password entry not allowed.a | |
| PIM | Disabled. | |
| PIM Snooping | Disabled. | |
PoE Fast PoE Perpetual PoE |
Enabled. Disabled. Disabled. | |
| RADIUS | Disabled for both switch management and network login. | |
| RIP | Disabled. | |
| RMON | Disabled. However, even in the disabled state, the switch responds to RMON queries and sets for alarms and events. | |
| sFlow | Disabled. | |
| SNMP server | Disabled.a | |
| SSH | Disabled. | |
| Stacking-support | Enabled. | Disabled for Extreme 7520 and 7720 only. |
| Stacking auto-discovery | Enabled. | |
| STP | Enabled. | |
| Syslog | Disabled. | |
| TACACS | Disabled. | |
| Telnet | Enabled.a | |
| VPEX IP Multicast Replication | BPE | |
| VPLS | All newly created VPLS instances are enabled. | |
| Watchdog | Enabled. | |
| Web HTTP server | Enabled.a | |
| Web HTTPS server | Disabled.a |
