This command disables session up/down trap reception for BFD.
| snmp | Configure SNMP specific settings. |
| traps | Configure SNMP Trap generation settings. |
| bfd | BFD-specific traps. |
| session-down | Generate trap when BFD session goes down. |
| session-up | Generate trap when BFD session goes up. |
Both session-down and session-up.
Use this command to disable trap reception for BFD session up/down.
The following command will disable trap generation for BFD session down events.
# disable snmp traps bfd session-down
This command was first available in ExtremeXOS 15.5.
