disable snmp traps
disable snmp traps
Description
Prevents SNMP traps from being sent from the switch.
Syntax Description
Default
Enabled.
Usage Guidelines
This command does not clear the SNMP trap receivers that have been configured. The command prevents SNMP traps from being sent from the switch even if trap receivers are configured.
To view if SNMP traps are being sent from the switch, use the show management command. The show management command displays information about the switch including the enabled/disabled state of SNMP traps being sent.
The following command prevents SNMP traps from being sent from the switch to the trap receivers:
disable snmp traps
Platform Availability
