Configures the circuit ID sub-option that identifies the specified ports to use the default value.
| port_list | Specifies a list of one or more ports that are to be configured to use the default value. |
| all | Specifies that all ports are to be configured to use the default value. |
The port_info is encoded as ((slot_number * 1000) + port_number). For example, if the DHCP request is received on port 3:12, the default circuit ID port_info value is 3012. On non-slot-based switches, the default circuit ID port_info value is simply the port number.
None.
unconfigure bootprelay dhcp-agent information circuit-id port-information ports 1:3
This command was first available in ExtremeXOS 12.4.
