unconfigure bootprelay dhcp-agent information check
Description
Disables DHCP relay agent option (option 82) checking.
Syntax Description
Default
Disabled.
Usage Guidelines
In some instances, a DHCP server may not properly handle a DHCP request packet containing a relay agent option. Use this command to disable the switch from preventing DHCP reply packets with invalid or missing relay agent options from being forwarded to the client.
To enable this check, use the following command:
The following example disables the DHCP relay agent option check:
This command was first available in ExtremeXOS 11.1.
Platform Availability
