show policy convergence-endpoint ports
show policy convergence-endpoint ports [port_list | all]
Description
This command displays the enable status of all supported Convergence End Point (CEP) types by port.
Syntax Description
port_list Shows enable status for the listed ports.
all Shows enable status for all ports.
Default
N/A
The following example shows the CEP enable status for port 3:
# show policy convergence-endpoint ports 3
Port        Cisco     LLDP-MED
   3             enabled   disabled
This command was first available in ExtremeXOS 22.2.
Platform Availability
