This command displays the status of dynamically assigned policy profile options.
| dynamic | Show status of dynamically assigned profiles. |
| override | Shows current status of which current profile assignment rules (administrative/dynamic) are overriding the other. |
| syslog-default | Shows current status of the default that dynamically created rules will have in sending of Syslog messages on rule applied. |
| trap-default | Shows current status of the default that dynamically created rules will have in sending of SNMP notification on rule applied. |
N/A.
The following example shows which current profile admin or dynamic assignment rules are overriding the other:
# show policy dynamic override Administratively assigned rules CURRENTLY OVERRIDE dynamically assigned rules for a given rule type. Image : ExtremeXOS version 30.2.0.31 by release-manager
This command was first available in ExtremeXOS 16.1.
The Syslog and trap default options were added in ExtremeXOS 30.2.
