Shows the MSRP stream information collected from the talker's attributes.
| msrp | Multiple Stream Registration Protocol. |
| streams | Data streams advertising QoS specification using MSRP. |
| detail | Show stream information with more detail. |
| propagation | Show stream propagation through switch. |
| port | Filter based on ingress port number of the stream. |
| source-mac-addr | Filter based on source MAC address of a data stream. |
| stream-id | Filter based on stream ID of a data stream. |
| destination-mac-addr | Filter based on destination MAC address of a data stream. |
N/A.
Use this command to show the MSRP stream information collected from the talker‘s attributes. The output can be filtered based on the stream id, source MAC, destination MAC, or port number on which the stream is registered.
# show msrp streams
Stream Id Destination Port Dec VID Cls/Rn BW
00:50:c2:4e:d3:2d:00:00 91:e0:f0:00:35:80 17 Adv 2 A/1 6.336 Mb
00:50:c2:4e:d3:2d:00:01 91:e0:f0:00:35:81 17 Adv 2 A/1 6.336 Mb
00:50:c2:4e:d3:2d:00:02 91:e0:f0:00:35:82 17 Adv 2 A/1 6.336 Mb
00:50:c2:4e:d3:2d:00:03 91:e0:f0:00:35:83 17 Adv 2 A/1 6.336 Mb
00:50:c2:4e:d3:2d:00:04 91:e0:f0:00:35:84 17 Adv 2 A/1 6.336 Mb
Total Streams: 5
BW : Bandwidth, Cls : Traffic Class,
Dec : Prop Declaration Types, Rn : Rank
(!) : Talker pruned or forbidden
MSRP Declaration Types:
Adv : Talker Advertise, AskFail : Listener Asking Failed,
Fail : Talker Fail, RdyFail : Listener Ready Failed,
Ready : Listener Ready
#show msrp streams detail
00:50:c2:4e:d3:2d:00:00 91:e0:f0:00:0e:80 17 Adv 2 A/1 6.336 Mb
Accumulated Latency(nSec) : 0
Max Frame Size : 56
Max Interval Frames : 1
Frame Rate (fps) : 8000
00:50:c2:4e:d3:2d:00:01 91:e0:f0:00:0e:81 17 Fail 2 A/1 6.336 Mb
Failure Code : (10) Out of MSRP resrc
Fail Bridge : 08:00:e0:e0:e0:e0:e0:e0
Max Frame Size : 56
Total Streams: 2
Dec : Prop. Declaration Types, Rn : Rank
# show msrp streams propagation
Stream Id Destination Port Prop VID Cls/Rn BW
Dec
Talker Propagation:
Ingress Ingress Propagated Propagated Egress
DecType Port DecType Ports DecType
Adv --> 17 --> Adv --> 19 --> Adv
21 --> Adv
Listener Propagation:
Egress Egress Propagated Listener Ingress
RdyFail <-- 17 <-- Ready <-- 19 <-- Ready
<-- AskFail <-- 21 <-- AskFail
Total Streams: 1
This command was first available in ExtremeXOS 15.3.
This command is available on all platforms that support the AVB feature and that have an AVB feature pack license installed. To see which platforms support AVB and for information about obtaining a license, see the Switch Engine v33.1.1 Licensing Guide .
