Shows MSRP talker attributes.
| msrp | Multiple Stream Registration Protocol. |
| talkers | Talker attributes. |
| egress | Display egress talkers only (default). |
| ingress | Display ingress talkers only. |
| port | Filter based on ingress port number of the stream. |
| source-mac-addr | Filter based on source MAC address of a data stream. |
| stream-id | Filter based on stream ID of a data stream. |
N/A.
Use this command to shows MSRP talker attributes. The output can be filtered based on the stream id, source MAC, or port number on which the talker is registered.
# show msrp talkers
Stream Id Port Dec Dir State Failure Code
App Reg
00:50:c2:4e:d3:2d:00:00 19 Adv Egress QA MT -
21 Fail Egress QA MT AVB incapbl port(8)
00:50:c2:4e:d3:2d:00:01 19 Adv Egress QA MT -
App : Applicant State, Dec : MSRP Declaration Types,
Dir : Direction of MSRP attribute, Reg : Registrar State
MSRP Declaration Types:
Adv : Talker Advertise, Fail : Talker Fail
Applicant States:
AA : Anxious active, AN : Anxious new,
AO : Anxious observer, AP : Anxious passive,
LA : Leaving active, LO : Leaving observer,
QA : Quiet active, QO : Quiet observer,
QP : Quiet passive, VN : Very anxious new,
VO : Very anxious observer, VP : Very anxious passive
Registrar States:
IN : In - Registered, LV : Leaving - Timing out,
MT : Empty - Not Registered
This command was first available in ExtremeXOS 15.3.
This command is available on all platforms that support the AVB feature and that have an AVB feature pack license installed. To see which platforms support AVB and for information about obtaining a license, see the Switch Engine v33.1.1 Licensing Guide .
